My yamaha 50 hp two stroke started up and ran just fine two weeks ago. This weekend, it started fine, idled fine, ran at low throttle fine. I could not get it past 3000 rpm. When I put the controls u wide open, I could feel the boat surge to full throttle for a few seconds, but then settle back to 3000 rpm. I changed the fuel seperator and ran fine. Hopped in the boat later and same thing. Low speed/idle works fine. Can't get high throttle/RPMs. Changed all the gas and no difference. Dropped it off at the marina and he is not sure what is wrong yet. Any ideas?
2002 Yamaha 50 HP two stroke
Remove fuel pump with 2-10mm hex bolts, leave fuel hoses hooked up, pump primer bulb and check for any fuel leaking out of small hole/port on back of pump....there should be none. Not a bad idea to replace this pump every few years(or hopefully before it fails)....just like with the water pump....
