No I haven't checked the compression yet. Picked it up last week, installed a new fuel tank and hose, changed the lower unit oil and water pump, installed new plugs and I've been sorting it all out since. The boat clocked 35.8 mph GPS on a slack tide which is about right for the boat so I would imagine it's running ok. I think the carb rebuild, which I've had to do many times over the years, should sort out the idle. Thanks for the heads up on the fuel treatment, apparently these yammies are quite particular about this. Look up Yamaha issues and gunked up carbs seems like the number 1....I know a lot of people swear by these 2 stroke Yamaha's so I didn't give it a second thought when it was included with the boat. I guess most of the old reliable engines are getting on in years now and the new etecs aren't really johnson/Evinrude any more so ones as good as the next. I put a lot of hours on outboards in a really harsh salt environment where engine issues can quickly lead to Coast Guard calls so unless I'm in a boat with sails, the engine is quite important. Being that I'm deAling with a motor I know nothing about, I'm sure ill be around here for a while. As said earlier, I've got an owners manual and shop manual enroute.
Maybe in the future, if this one turns out to be a good runner, ill look into swapping out the trim unit for a TLRV unit. Again, thanks for the info, tips and advice. If I've learned anything so far about Yamaha outboards, it's that they have a good support forum.
