Hi,
I'm after some advice as I have been trying to troubleshoot an idle/low rpm issue without success for a while now.
I have a 1989 Yamaha 50hp, 3 cylinder, 2 stroke (6H5 L 511690 D) which starts straight away but will cough and die after about 30 seconds as seen in the first video. After the carburetor link adjustment the engine will idle for a bit longer as in the second video and it is similar at low rpm where it seems to be misfiring. Engine seems to run ok at all other throttle positions and will only keeping idling if the remote choke lever is used, which appears to adjust the timing?
As the boat I bought had been in long term storage fuel was the starting point and I have checked the following to date:
- Drained and replaced the old fuel
- Fitted new spark plugs (All three were similar and are black/wet, slightly rich?)
- Cleaned the carbs by hand several times, including soaking in carb cleaner overnight and running the jets through with mono fishing line. Checked the float heights are in spec (15mm +-1mm) and pilot screws 1-3/8 +-1/4 turns
- Carburetor link adjustment (This did improve the idle time before dying
- Checked compression (#1 130psi; #2 135psi; #3 132psi)
- Charging is ok and battery condition ok
- Visually inspected the reeds but not removed and look ok
- Replaced fuel lines and connectors to the engine
- Checked fuel pump and fuel filter seem to be ok
- Checked Throttle link adjustment (CDI unit indicator, full retard ATDC 7° Full advanced position BTDC 25°)
- It appears #3 cylinder is intermittently firing at idle (will fire on only #1 or #2 but not #3 cylinder)
- Swapped enrichment system from another engine (does not start as well and no change to the idle issue)
- Swapped #3 coil from another engine
- Swapped #3 carburetor from another engine
- Swapped CDI from another engine
- Coil resistances seem to be ok (Primary ~0.3Ω Secondary 7.8 - 9 kΩ)
- Resistance of pulser coils seems to be ok (180, 184, 182 Ω)
- Peak voltage from charger coil, pulser coils and CDI all seem to be ok and above min specs
- Checked resistance of charger coil seems to be a little low (302Ω) but similar to another one tested & peak voltages are above min
