Hi peolpe!
just purcahesd a 130 beto v4 2 stroke in fantastic condtion and 120 hrs run time on clock.
Problem a tad hard to start ? choke then fires then need some throttle to get goin.
Ounce goin bang ! instant
Runs well ! sitts at rest around 7 to 8 rpm in the water and sits bang on 8 on the hose.
Then the probs start ,somtimes starts bang and runs like a plugg missing
re start fine.
Idle to power up burrrrrr restrcts almost to stall ,back off back to idle.
came back at 4900 rm perfect,droppoed back to idlespeed coming up againts tide motor working under load wont go past 1200 any more spluutters and threatins to die ?back off idle fine
put in neutarl revs its head off,back in gera burrrr wants to die.
drive on trailer power on burrrrr dies,turn key off and re- start stutter vroom ! full blast.
New fuel tank leads and coneections,all new pluggs,carbys off and cleand ,new external fuel filter .
Compression all top end.
Thinkin somthin electric ? when it cuts out it starts straight away? most times .
somtimes it miss fires ant wont turn over,sometimes it fires sneezezes and conks ..
Local mechanic sorta bewildered ?
Any electrical tests we can run ?
test drove this engine before i broguht it exccellent never an issue with previious owner ,layed engine down brought home and re installed nothin but troble day 1.
re start fine.
PS..just reread your post...what do you mean by "sometimes it wont turn over" ??? as in not cranking ??
