Simple question on water pump kit... where does this go?
  • Simple question on water pump kit... where does this go?
    I am looking at the cylinder shaped seal to the left of the bolts. There was not one on my 1995 P50TLRT motor when I took it off. I suspect it might go on the water pick up tube on the motor side?
    Sorry It is a 1995 P50TLRT. I believe this is the PN 663-44366-00-00
      it is the key that goes in the shaft and keeps the impeller spinning with the drive shaft
        It's a woodruff key that goes in a slot on the driveshaft ....this key fits in a key way or slot on the inside of the impeller....you can tap the old key out with a screwdriver and a small hammer....then just tap the new one into the slot...it should be a tight fit...
          I am looking at the cylinder shaped seal to the left of the bolts. There was not one on my 1995 P50TLRT motor when I took it off. I suspect it might go on the water pick up tube on the motor side?[/QUOTE]
          __________________________________________________ _______________________
          It (the seal) goes on the underside of the main housing, sealing it up.
          Part #24 (seal), resides under/in part #21:
            Thanks guys, I see it now - the one I am looking at is actually #25 here. (not shown in your drawing for some reason).
            It's the little tube shaped seal that goes under the white plastic piece which snaps into the pump housing. The water pick up tube then mates with that seal after it is guided in with the white plastic part.
            https://cdn.crowleymarine.com/yamaha/ioiEXsdu.png
