I have a question
  • I have a question
    Has anyone tried it? Danger to the engine or not?
    My motor :yamaha F225 thanks
    What is it? The picture is too small.
      More than likely no damage and no benefit.
      Unless its use makes one feel better. Then use it.
      Corporate profits are based on this phenomenon. A win win situation.
        IME, Yamaha's RingFree works very well...
        I use it regularly in small engines (carbs just cleaned) and will re-tune and usually get higher RPMs after sitting overnight with a treatment.
        I also run it in every gas machine I own regularly..
            it's fuel injection cleaner product. Used with cars at my home.
              How well it will actually work can always be debated. But you certainly won't hurt anything by using it.
              However, if you're questioning your injectors, or just want to do something that DEFINITELY works, have them cleaned. It's only about $20 per injector and you can send them to a place online or if you're in/near a decent sized city, there's probably a local injector shop. Ask around at places like a NAPA - they'll probably know.
                thank you guys
