I have a pair of F250's which have been running well. I went out in the boat this weekend and the starboard engine will not go above 4000 RPMs.
Plugged into Yamaha computer diagnostics to see if there were any obvious faults, but nothing stands out to me as I don't know what the correct numbers should be at idle.
What should I expect to see out of the TPS voltage output readings? The computer shows two TPS, but they are showing different voltage readings.
I am trained on other platforms, but not this. Any help would be greatly appreciated.
