Here is my problem. You can pump the bulb all you want and nothing happens. If you take the fuel line off the canister ( you can tell that the line has pressure in it) then pump the bulb until fuel comes out then hook it back up, the bulb will get tight and the engine will start. engine will run fine all day. Next day same problem the bulb will not be tight and you will have to start that process all over again. So here is what I have so far. I replaced all fuel line between the fuel tank and the bulb. Replace the bulb with a new Yamaha bulb. Still the same thing. Is there a check valve somewhere after the canister that could be stuck? Low pressure pumps bad?Any other ideas?
Thanks.
Thanks.
