Valve Adjustment F150
  • Valve Adjustment F150
    Necessary or not so necessary?.How many hours realistically?If not broke should it be fixed ?What to expect .
    In the sticky section here, scheduled maintanence shows 500 hrs or 5 years.
      An adjustment is based on the clearances between the camshaft and the valve actuation mechanism. If clearances are in specification then no adjustment is required. If clearances are not within specifications then an adjustment needs to be made.
      Only an inspection of any particular motor will determine if an adjustment is needed or not.
        Anyone happen to know the part number/price for the shim kit f150 txrd 4 stk. Thanks
          What F150TXRD shim kit? Who makes it? It is not Yamaha. Yamaha does not offer a "shim" kit.
          Although the engine is to be inspected for valve clearances it is somewhat doubtful that you will find them out of specification. If you do, then you will simply purchase whatever shim thickness is needed to get it back within specification.
          There is a trick that you will need to learn in order to get a shim out, and a new on in, if you need to replace one.
          Item 8 within this illustration are the shims, or what Yam calls pads.
          2005 F150TXRD Yamaha Outboard VALVE Diagram and Parts
