Looking for help with a spark issue. No fire at all on the #2 plug. Swapped the coil pack with the #3 and the problem stayed on the #2 cylinder. Both 1 and 3 are firing strong. Where do i go from here? Rectifier? CDI? Any help is greatly appreciated. Thanks
yamaha 70 no spark on #2
from what Boscoe mentioned it sounds like that 70 is similar to the 90,
only 2 pulsers for 1 & 3, so the crank position sensor and CDI get together and decide when to fire #2
service manual should have the proper testing of the CPS
Originally posted by 99yam40 View Postfrom what Boscoe mentioned it sounds like that 70 is similar to the 90,
Originally posted by 99yam40 View PostI would check all wiring connections too
I worked on my BIL 50 that was doing that, all I found was the bottom carb main jet had some debris in it.
did not make any sense to me that would cause a bog and motor to die from just one jet being partially plugged, but it ran well after I cleaned the carbs
Originally posted by 99yam40 View PostI worked on my BIL 50 that was doing that, all I found was the bottom carb main jet had some debris in it.
have you replaced the plugs?
they are cheap enough to just try a news set
motor needs good compression ,good spark at the correct timing, and the proper fuel to air ratio to burn properly and create power to push the boat.
have you checked to make sure timing is advancing when you give it throttle?
induction timing light will show what the timing is doing and also show if each plug wire is getting spark thru it
everyone should have a good timing light
My guess is the shop replaced the CDI on "suspicion" and it didn't fix the problem, charged you and you're back where you started, clean the carbs thoroughly, washing them and spraying them is NOT cleaning them, also as mentioned, make sure the timer base is moving with the throttle.
Originally posted by ausnoelm View PostMy guess is the shop replaced the CDI on "suspicion" and it didn't fix the problem, charged you and you're back where you started, clean the carbs thoroughly, washing them and spraying them is NOT cleaning them, also as mentioned, make sure the timer base is moving with the throttle.
Guys i really appreciate the input!! Im trying to learn. Never know when a little bit of extra know how might help get me back to the boat ramp!!
Originally posted by 99yam40 View Postwell I guess we still do not know exactly what 70 this is you are working on.
what controls the timing?
So far since this bogging started i have done the following
- new ngk spark plugs gapped to yamaha spec
- new fuel line amd primer
- tank drained and cleaned, fresh non ethanol
- carbs cleaned, jets replaced
- strainer removed and cleanedLast edited by the Lackster; 04-14-2021, 07:24 PM.
OK, it has a timing plate and linkage that should move as the throttle is opened.
Does it?
do you have a timing light to see what the timing is doing?
and what did this mean about checking voltage into the CDI ,having it there but not out?
what did it measure to be , what did you measure it with ,and and does it have the proper voltage now?
sounds like #2 is sparking now, correct?
explain better about the "The boat wont get past idle if i give it throttle but manually push the carb linkage it will try to dig off."
what linkage did you push?Last edited by 99yam40; 04-14-2021, 07:46 PM.
Originally posted by 99yam40 View PostOK, it has a timing plate and linkage that should move as the throttle is opened.
Does it?
Ok, the arrow on the timing plate moves when you push the throttle, if its moving correctly or not i have no idea. I do not have a timing light.
- all i had to check with was a klein multimeter. I dont remember the exact reading on the cps but it was within the range listed in the service manual. I was not getting any output to the #2 coil pack though. Yes, #2 is getting spark after the cdi replacement.
- the boat doesn't want to rev up even with the prime start lever at the control but if you open the carbs buy pushing the linkage that connects the carbs it will rev up and i can see all 3 spraying fuel mix.
- this issue started a while back but was intermittent until recently.Last edited by the Lackster; 04-14-2021, 08:05 PM.
ÂÂÂÂ
