F300 DEC & DES Question / Help
  • F300 DEC & DES Question / Help
    Ordering a new Bennington 24LXSB Tri Toon with a F300HP - Sea Star, Power Assist Steering
    4S DEC V6 25"
    $24,032
    4S V6 Integrated Steering 25"
    $28,308
    What is the integrated steering ?
    I found some data on DES which seem to replace the Hydraulic steering
    Hoping if someone could me understand the options above. When I ordered the boat only the 300DEC was a option and since then they added integrated Steering Option
    Note: The boat is rated for 350HP but was told they are discounting the V8 350 for flywheel issues so drop down to the 300HP which will push the pontoon near 50MPH which is more than enough
    Thanks in advance for any help
    PT
    see if this helps
    Digital Electronic Control (DEC) models boast built-in Digital Electric Steering (DES),
    Newsroom | Yamaha Outboards
      It is safe to assume that if I ordered a 300HP DEC I getting the new DES bolted on version?
      The Integrated Steering motor shows as a $3,700 upgrade does Integrated mean built in DES over the bolted version?
        All I know is what that link says, did you click on that link and read the article?
        I would think the people you are buying from should be able to answer all of your questions better than unknown people on a forum.
