Paging Mr. Rod Bolt
  • Paging Mr. Rod Bolt
    2001 Yamaha OX66 250HP SX250TXRZ
    #1 is without spark. or intermittently fires but mostly without.
    With my timing light hooked up and with motor on hose,
    I crank it up and engine goes straight to high warmup idle and while on high idle
    #1 sparks good for about 5 seconds and then maybe blinks the timing light once or twice every 4 or 5 seconds
    # 3 does the same intermittent spark but mostly not firing at all and # 5 is with out spark the entire time.
    Engine idle falls down to normal shortly thereafter as it should.
    It's not my timing light, as #2 #4 and #6 (the port bank) are firing fast and consistently.
    So basically, my starboard bank's spark is not there or intermittently flashes on very briefly here and there.
    I have looked at and swapped coils and caps.......not the issue
    I have followed and inspected everything, wires and plugs for broken or corroded or chaffed......everything looks great
    If I am not mistaken, isn't the entire ignition basically the stator, the pulse coil under stator and the CDI?
    I popped the flywheel off and everything looks real nice under it, I swapped the pulse coil with a good spare I had and no change.
    I am hoping it is a stator, i don't have a VOM with ability for peak reading nor sure I would understand how to test anyway.
    I have it off and on the bench, I have a VOM.....anyone know what I should ohm out and what it should spec on bench?
    Shift interrupt switch tests fine
    If you were a betting man, stator or CDI unit or something else?
    Thank in advance for any help
    Mr. Rod Bolt has long since left the building. Apparently never to be heard from again.
      Well he certainly knew his stuff. I am sure there are other fine techs on here as well.
      Thoughts? Anyone ?
        I am not much help, but search for CDI electronics trouble shooting guide on the web
          bump for your thoughts, stator or CDI or something else?
            that is the reason for troubleshooting, to find out what the problem is
              Fixed - was CDI unit
                well did you test things or just throw parts at it and hope?
                could it have been a bad connection in the wiring to the CDI?
                  another helpful post, thanks again,
                    so it sounds like it was a shot in the dark
