I need help with a no spark issue on my 1999 90hp. I have used my repair manual to trouble shoot a problem with the ignition system on my engine. A little background. The problem has been intermittent, until now. I am getting no fire on the #3 (bottom) cylinder. At first it seemed that the problem would develop when the engine warmed up, however, now it occurs immediately after starting.
I have switched out the coil and put in a new plug so I know thats not the issue. Following my repair manual I have tested the pulser coil resistance and found it within the limits at 326, the crankshaft position sensor and found it within range at 217, and the ignition charge coin and again found it within range at 80 and 248.
I had two failures, the ignition charge coil output failed at cranking speed, 11 volts, 1500 rpm .. 50 volts, and 3500 rpm .. 54 volts. The pulser coil output test failed at all three intervals as well, showing very low voltage, less than 2 volts.
** note ** I performed the tests with the boat hanging in the sling, as well as out on the water under a load. Results were basically the same.
Reading the manual it would seem that both my ignition charge coil and pulser coil are bad.
My question, which I have not been able to find the answer to in the manual, does one system affect the other. In other words, are both coils bad, or is only one bad, which in turn causes the other to fail the test. I guess I find it hard to believe that both coils have gone bad at once. Or is there something I am missing in my reading of my manual?
Thanks in advance for any assistance.
