The idle on my 1998 two stroke Yamaha 25 hp outboard motor model # 25ELRW is running about 1400 RPM. The idle adj. screw is completely adj. out to lower idle but 1400 is as low as it will go. I've adj. the pilot screws and set the static timing but with the idle at 1400 I can't set the timing with a timing light. I've also disassembled and cleaned carburetors, and choke is full open. So my question is how can I lower the idle to factory spec of 800 to 900 RPM.
idle
Originally posted by fisherman363 View PostThe idle on my 1998 two stroke Yamaha 25 hp outboard motor model # 25ELRW is running about 1400 RPM. The idle adj. screw is completely adj. out to lower idle but 1400 is as low as it will go. I've adj. the pilot screws and set the static timing but with the idle at 1400 I can't set the timing with a timing light. I've also disassembled and cleaned carburetors, and choke is full open. So my question is how can I lower the idle to factory spec of 800 to 900 RPM.
too far advanced will increase Idle RPM
If the timing is off, then the carb adjustments get out of wack when you adjust them trying to correct it.
My 99 C40 was too far retarded when I bought it 3rd hand.
I did everything I could think of to correct it and get the motor to idle properly,
but ended up replacing the CDI as that is what con*****ed the timing on my motor.
not sure if your motors timing is manual con*****ed with linkage or con*****ed by the CDI,
or even if that is the problem, but you need to find a way to correct the timing
Â
