Charging system on my 06 25 hp 2 stoke
  • Charging system on my 06 25 hp 2 stoke
    Added a volt gauge to my boat and had 17 bolts at full throttle
    seemed high to me
    put In a new regulator with same results
    ​​​​​​ any thoughts?
    17 Volts not 17 Bolts
      have you tried measuring the voltage with another hand held meter to see if they agree on voltage?
        The way that it is. High voltage but low current. Not unusual.
          but would the regulator control that voltage better, or is this RR just a rectifier and not also a regulator
          would the service manual give specs for just minimum and not max?
            Parts catalog shows it as just a rectifier. No voltage control.
            You could try an aftermarket R/R and see the results.
              I measured voltage with hand held meter and get same reading as volt meter on boat.
              I did try an aftermarket reg like I originally posted with same readings.
              Just thought I would try to get some feedback about this issue
              thankyou
                Are you sure that you installed an R/R and not just a rectifier? Does it look like this?
                Here is a relatively inexpensive R/R.
                https://www.dbelectrical.com/product...230-22196.html
                  The regulator I bought looks like that
                    that picture is of a rectifier, not a rectifier/regulator
                      Second picture looks like a bridge rectifier, but has regulator written on it. The first has 5 wires. How can we really tell?
                        and the pic says it is a rectifier relay.
                        what is a rectifier relay?
                        the link, does look like a full wave bridge to me
                        what is a regulator?
                        a zenor to bleed off excess voltage?
                          We tend to think a regulator should be more than a zenor diode that shuts current to ground.
                          A more sophisticated regulator still will use a zenor diode to sense voltage, the difference being a transistor or triac/thyrister and associated components are added to block current flow and therefore doesn’t waste the excess current.
                            from what I understand Yamaha does shunt excess current to ground to control voltage
