New to this forum and I have a question on removing the lower unit to have it pressure tested at my local marina. 5 screws located on the bottom....
Are there any other mechanical/connections to disconnect to remove the lower unit? It looks as though there is a "tube" or rod that sits inside the engine cowling running from the lower unit up into the engine area...
Any help if you are familiar with this model would be greatly appreciated
Thanks!
Thanks!
