Originally posted by rodbolt17
View Post
Yamaha would say that the motor exceeds their performance requirements for compression. If you can find in the service manual where a leakdown test go/no go value is provided I would like to hear about it.
What did you find out?
Now all along I have been talking about compression results on a motor that is otherwise in good condition. If there is a problem which cannot be found then certainly a differential pressure check would be a good idea after a direct compression check has been performed.
