Just got head rebuilt from yammie dealer but engine cuts off at idle which is 500rpm. Do I need them to increase the idle speed, (will run at 600-700rpm but shut off at 500rpm, or maybe gas problems, which has E-gas that been in boat for almost A year with stablizer in it. Most online mechanics say E-gas is bad for outboard especially carb. Engines. Need advise.
idle speed 2002 100hp carb. 4 stroke
carb. idle
yes carbs. were rebuilt and it ran fine the first day in the water, but the second time I notice it was cutting off at idle. Worrying about this situation I started it just yesterday in the yard sitting in 55gal drum, it runs ok at 650-700 rpm, but when I drop it back to neutral or idle 500rpm it cuts off. Will try to bring back to yammie dealer to find out problem, gas or carbs adjustment.
