Folks the attached file is on my 2006 Yamaha HPDI. And yes before asked the hours is correct, there are only 9 hrs.
The only thing which concerns me is the electric oil pump. It's result reads as "low" but I don't know if that is normal at idle and running on 4 of 6 cylinders.
I'm wanting to put this boat in the water and would like some opinions if it is ready. This motor sat for a long time. I have replaced the water pump impeller, the lift pumps, the electric fuel pump and filter, the fuel regulator, medium pressure fuel filter canister. I also dumped the fuel tank and fresh filled with non ethanol gas.
Thanks for the inputs in advance.
