2003 F50 TLRB starting issues
  • 2003 F50 TLRB starting issues
    i have a 2003 yamaha F50 TLRB with the 4 carburetor set and prime start.
    i have a very hard time starting the motor.
    1} i would squeeze the bulb and hear the gas is pumping into the fuel filter and the bulbs is hard.
    2} i would pump the throttle forward and back to neutral at least 8-10 times.
    3} turn the key, sometime it start but most of the time i would have it would not and i would have to give it 3-5 more pump.
    4} after it warm up in it run flawless, no hiccup or anything...just flawless.
    5} turn off the motor and fish for 30 minutes or so. and again i would have to squeeze the bulbs and pump the throttle back and forth 4-5 time before starting again.
    i have water in between my fuel line.
    clean out my carburetor once in every 2 years and it always clean inside and out.
    alway fill up my gas at chevron mid grade and use YAMAHA RINGFREE and Startron additives on every fill up.
    i live in california and use my boat just about every week.
    is this normal?
    bought this boat used 6 years ago.
    any suggestions?
    is this normal?
    any suggestions?
    I would get rid of all the water in your fuel system(tank,pump,carbs,& and lines), if that is what you are saying
      Your engine is carbureted and you do have prime start on carbs 1 & 3.
      You should not have "pump the throttle" for start up. Opening the throttle is leaning out the mix, if anything, working against starting cold.
      https://www.boats.net/catalog/yamaha...lrb/carburetor
        I will be taking the carburetor apart and clean them out again this week.
        Hopefully everything is good..
          I am a young man who dreams of becoming an outboard technician in Korea. The carburetor must use a choke during initial startup. However, your model has a prime starter, so you can check the prime starter.
