I have a 1987 V6 EXCEL XH 225HP outboard mounted to a 22 Grady White Serial #701041.
Everything runs fine and has been reliable for me. However, I have an oil leak each time I take the boat out of the water and the motor is tilted up. The leak appears to be coming from between the seal of the oil level sensor and the main oil tank. The oil collects in the base and I have to sop it up before using it next. If not, it seeps down the outside of the lower unit and goes in to the water. Not a good thing...anyway, I thought I could purchase a new oil level sensor which would improve the seal and fix the problem. HOWEVER, all the parts suppliers I searched show the part (6G7-85730-01-00) as "not available."
Does anyone know of a replacement part and/or have any suggestion how to improve the seal?
