The F90TLR runs rough or stalls at idle.
I posted a thread about this ISC valve about 1 week ago. When I close this thread out will reference the other thread for future documentation.
Using YDS 1.33 on my F90TLR I ran the Stationary (ST) and Active(AT) tests.
Part of the ST is the 'Operate ISC valve'. From what I gather the valve range is suppose to be between 0% and 100%. I saw up to 70%, didn't record the low %. I did hear the valve stepping when testing. In all cases I didn't hear the stepping(rattling) when turning the motor, I listened closely. At this point, I have evidence that the ECU, ISC wiring and the step circuitry in the ISC valve are functional.
For the 'Active test' I did the 'Fully Open ISC' and found the YDS displayed from 12% to 100%. For the 'Angle of ISC value opening' the test started with the ISC valve opening at 60% and by the end of the test it was 0%. Part of the process of this test is to adjust the angle of ISC valve, my service manual doesn't say anything about how to adjust this.
All other parameters/test using the YDS were within specs.
During my testing, ~ 2hrs, I started/stopped the motor several times. About 50% of the time it ran normal and the other 50 abnormal (rough/stalling idle). When it did run abnormal I shutdown and immediately ran the ST-Operate ISC valve which pulses the ISC and displays the results. In all cases, immediately following I would start the motor and it ran smoothly.
Based on the above paragraph my conclusion is that the ISC valve is intermittent but am reluctant to make the plunge for a new valve until I get some feedback.
Here's my q's.
1. based on the experience in this forum is my initial analysis flawed or am I on the right track?
2. are there any additonal tests I can do to verify the ISC is defective?
3. is it possible to have an interrmitent ISC?
4. can the ISC be cleaned/soaked?
5. how is the angle of the ISC adjusted and is it critical in this situation?
Here's my q's.
