Autolube leaks through engine
  • Autolube leaks through engine
    Hi everyone! Im new at this forum but my problem is old. I have a 70b, probably 1989. When i havent started the motor for a couple of days i get heavy smoke when i start. The problem is that the lower cylinder has a whole lot of two stroke oil in it. The autolube seems to leak oil into the engine while its not running. Where do i start to search for faults? Is it time to change the oil pump?
    Best regards
    Emil
    Leaking check valves would be where I would start if that old of a motor had them
      the kien pumps prior to 1990 had the check valves in the pump.
      the kien pump has been NLA since 1990.
      the later mikuni pumps used inline check valves.
