At idle speed the motor dies or runs extremely rough. I can restart but it runs rough. I have been noticing over the last month that it doesn't start as quickly as it did in the past. It may take 3-4 cranks when it used to take 1-2 cranks.
I shocked the fuel system by replacing the water filter and before installing filled with AimsOil gas additive concentrate. The local marine mechanic suggested this. I then ran at least for 30 min.
At WOT it runs w/o any issues or so it seems. The tach at 25mph may be slightly higher than norm but I can't say for sure.
This issue started 2 days ago when I got a crab trap caught in the prop. Is this coincidence or could that have caused the issue? Maybe jump timing?
I've checked water filter and first filter coming into the motor and both were fine.
The plugs are all the same, black dry (not wet) coloring similar to a rich gas mixture. When it runs at idle it sounds like the restrictive rpm (for low oil or hi temp) has kick in but runs at high rpm.
I did an ohms check on the spark plug wires and they are between 5-7Kohms.
Any suggestions?
Any suggestions?
