Well it's time to get the boat running again aafter trhe winter and I have a small problem that maybe someone can help with. I can not get the boat started using my key ignition. When I turn the key to the first position eveything lights up on the tach as it should but when I turn the key the tach goes blank and nothing happens. I am able to get the motor started by running jumper cables from the battery directly to the starter. It then starts up fine and runs well. Is there something in my key ignition that is wrong. I checked all the connections and they seem to be fine. This boat is now 22 years old so maybe it just went. Any ideas
I have one other issue, Once the motor is running the overheat alarm goes off after about 5-10 minutes from a cold start. I am running the engine on a pair of ear muffs with ample water flow from the hose. The flow coming from the engine is a lot weaker than I usually get when I would run in the water. Last year I replaced both thermostats and the impeller was changed. Any suggestions would help.
Glenn
Glenn
