Been a while I have been here. I want to know if there is any newer carbs that I can install on my pro v 150? Long story is I am tired of rebuilding theses carbs. Been thru them over a dozen time with multiple new kits. Cleaned them completely each time. I mean fully gone through. The problem is they keep flooding out. Was out yesterday and started it up. Sounded like it would run a few seconds then die. Did this 5 times. I removed the cowl and there was a ton up fuel all over the carbs. I mean at least a pint in the bottom of cowl. Replaced all fuel lines and drained both fuel tanks then cleaned them very clean. So been the the entire fuel system. Pumps are less than 2 years old. After each time going thru carbs I have linked and sync. My fist thought was the needles fell off or got stuck open but on all 3? So now I am wanting to replace them with some newer carbs that would fit my engine. Ran out of other things to think of.
Thank you
Thank you
