Hi,
I have a 1991 Yamaha 25 2-stroke that boggs down at WOT. It runs great at idle and at lower speeds but once I go full throttle(5400rpm) for about 30 seconds it boggs down to a stop. I can hold the throttle in the max position as it does this and it sputters for a few seconds, then all of a sudden back to full speed and then does the same thing over again. Priming the bulb does not help...it stays firm. I started off checking the timing. Then I replaced the fuel diaphragm, the fuel lines, all the gaskets, and spark plugs. The fuel filter was clean so that was not replaced. None of that fixed it so I then cleaned the carbs, replaced the gaskets, and got new floats/needles. The lower carb showed signs of a stuck float so that was replaced. This also did not fix the problem. Next, I replaced the stator because I thought it was a faulty pulser coil. That also did not change the issue. One thing I've noticed is that the motor runs further WOT when the motor is cold versus when fully warmed up.
Does anybody have any thoughts on what to look at/ replace next?
