Hi Guys,
I have recently bought a boat with a 2014 Yamaha F115LB. I just found out that the lower is from a 2004ish 90hp yami. After looking at the parts diagram it looks like these are a bit different. The F115LB has a steady bearing near the crank while the 90 does not seem to have it. It is mounted and seems to be shifting and pumping water. Does anyone know if these lowers are compatible?
I also may have a line on a 2012 F115LA lower. If the 90 is a no go would one this lower work on the F115LB?
Thanks in advance
Steve
Thanks in advance
Steve
