i have a 1993 9.9 yamaha that loses prime while running i pump it up and it will run fine then all of a sudden if i dont pump the ball it will stall when this happens the ball is soft and it seems it is starving for gas i changed the fuel diafram and it still does it any ideas????
9.9 yamaha losing prime
I am having the same problem with a 1997 9.9 high thrust.After you prime up the motor it will run fine and it will slowly start to sputter and die . If you pump up primer bulb it will run fine. New primer bulb assy. and fuel lines.I took the fuel pump apart and there where no holes in diaphram. any ideas?
ÂÂÂ
