How to connect Cut cable from Oil sensor on Yamaha 40VMHO , 2 stroke autolube
  • How to connect Cut cable from Oil sensor on Yamaha 40VMHO , 2 stroke autolube
    Hello, The wires on my outboard were destroyed by mice. I asked an electrical technician , who connected them, but then after he left, i saw a Pink cable coming out of the Oil sensor that was cut, hanging , not connected.
    The engine starts , but only goes on slow speed, does not develop speed. Could it be on safe mode due to the cable not connected? The led light on the front is OFF. The 2 wires from the led, go now to the engine, not to the oil sensor. I dont know if the electrician did correct connections.
    Any idea where i should connect this pink cable? The Black cable that comes out of the oil sensor , i put it in Ground.
    thanks
    What is the engine ID please? Begins with the number 6.
      Hello,
      the serial number that i see on the book is 490507. I dont see other numbers as the engine is old and i canot find other numbers.
      Hope this can help to identify it
      thanks
        Look at the CDI please. What are the markings?
          Looks to be the equivalent of a 40MLHT distributed here in the USA. Best that I can do is to send you a wiring diagram.
          Send me your email address via PM please. I would post it here but for some reason anything attached hereto is fuzzy as hell. Almost illegible.
