I have a 2001 200HP OX66 with about 950 hours , on a trip to florida in august the motor started to make a chirping noise , ran all the normal diagnostics compression ranges from 109 to 120 psi , wrist pins dont seem to have any slop .
took it to an outboard shop and the think it is something in the crank , possibly the upper crank bearing , before I spend a fortune I would like to confirm the source of the noise
I pulled the flywheel , stator and pick up assembly I am curious of I can pull the seal retainer and gain access to inspect the bearing without having to pull the power heard to split the case
I can tell by the parts diagrams if there is a locating pin in the housing , any thoughts ?
