Trim and Oil Harness Motor End
    Okay, with the persistence from both, I decided to disconnect the only “Ivory” colored 4 pin connector and then inserted the Trim/Oil connector. Lo and behold, it looks like the missing link to the puzzle.
    The only "Ivory" colored 4 pin connector plugged together
    I disconnected the connectors
    Plugged the two connectors from the trim/oil harness.
    Viola! Hope this is correct .
      and that is how it works.
      why someone plugged them together???? cause it fits.
        Seems I have read if they get plugged together when they should not be ,it can cause some problems.
        Memory is not too good so I am guessing at this,
        maybe it caused false alarms.
        • #19
          Sure hope it doesn't/didn't cause any poblem .
          I'll know after I finish the modifications and installation back on the boat.
          • #20
            Just a follow-up on my repower. Motor fired right up with tach and trim control operational. I still need to re-install a couple of items...T-top, fuse panel and fresh batteries before launching this weekend for a trial run.
