if #1 pulser output was a problem then I would think it would just not fire when it should,
but I have no idea why it would fire when #2 was suppose to.
it would be nice to find another CDI just to try and see if that made any change.
look at the wiring real close to see if you can see any physical damage where #1 and #2 could jump between
might require pulling the flywheel to inspect all the wiring and check the pulser coils gaps if the testing shows a need to
the timing is con*****ed by the CDI and that wiper on it, so I would think it would move as the throttle plates move or even before they move.
if you disconnect the linkage to the wiper then they can be moved indepenantly
