For gods sakes !! Leave the timing alone. If anything, retard 2 degrees. I can't remember the last time I had to mess with the timing. And I work 7 days a week in the boating season.. same with carbs syncing. Unless someone messed with carbs.
They DONT go out of sync very easily. I always check the cam pickup for wear and note at Idle the gap or da mark
I also always ck carb throttle plates for WOT. You be surprised from the factory they are close, but not Wide open. I have also seen them open past the correct mid way point.. always remember, boat builders are fiberglass/alumanan pros not propulsion experts. Same goes with alot of boat dealers..
