I removed my lower unit to replace some seals because I am still finding water in the gear oil, even after replacing the prop shaft seals.. There was no hose (#18) or nipple (#19) connected to the nipple (#17), which was there. I can see there is a hole in the upper casing right above the nipple that apparently the hose exits the lower unit from. Where does this hose go from there and what is it's purpose? Would having no hose allow water to get in the gear case?
EDIT: After continually searching I discovered it is for the speedo. Since I don't have one fitted, I guess I can ignore it...
