I installed the 6J8-48501-03-4D REMOTE CONT. ATTACHMENT ASSY this weekend and removed the tiller handle assembly. I was trying to install the steering hook 6J8-48511-51-4D, not sure where it goes. Looks like a bracket should bolt up to where the tiller assy did with 2 bolts. Any ideas?
25MSHA3 tiller to remote
Part #25 has two studs and the steering hook only has 1. I have attached a pic of the steering hook. I think.Attached Files
Take a look at this illustration of part number 6J8-48511-51-4D.
2006 and Later 25ESR Yamaha Outboard CONTROL 2 Diagram and Parts
Originally posted by BAYFISHER View PostThe 6J8-48511-51-4D (superseded by 689-48511-02) only has one hole in it.
Yamaha US has this part (6J8) in stock. Boats.net shows that it (6J8) is available at $51.69.
Boat Parts: 6J8-48511-51-4D
The Yamaha outboard rigging guide shows the 6J8 part as being the required one for a 25 HP. Not the 689 prefix part number.
6L2-48501-11-00 Throttle & Shift
689-61350-02-00 Steering Arm
6J8-48511-51-4D Steering Hook
Where are you getting your information from?
Here is an illustration of your motor.
Have you removed item 33? If two studs, washers and nuts were used to attach item 33 does it not stand to reason that two studs, washers and nuts are needed to attach the steering hook? Wouldn't that steering hook need two holes to interface with the steering bracket?
Here is something else to think about.
The steering hook that I think is the correct one has a 6J8 prefix. Now look at the steering bracket assembly for your motor. It also has a 6J8 prefix. The start of the model identity for most/all 30 HP motors is 6J8.
Those prefix's will tell a story is one is listening.
ÂÂ
