2004 Yamaha F150.. Engine will speed up to 4400 rpms and will not go over 30mph.Stops at that range rpm and then starts to bog down slowly. When it hits 25 mph the engine will stabilize and level out . Will not accelerate ..The throttle is pinned .Not noticing any roughness and seems smooth at that level. I am thinking it is restriction somewhere on the low fuel side, or a bad fuel pump perhaps. Appreciate any thoughts /ideas.. Thanks
Diagnosis help?
OK checked the rail pressure and its 38 running 42 at rest This is at idle and revved up a bit 2300 rpms .. Working in a tank . Noticed a little black dry soot on couple of spark plugs. Wont go over 4200 rpms and not over 28 mph.. Noticed some fuel in the over flow vapor canister. Runs a little rough at idle , not perfectly smooth.. Any ideas ..appreciate Thx.
I just replaced the needle and seat last year.. Looks like this could be a yearly thing.. Maybe some dirt , but do you think this is the cause of lack of power (Roughness) at speed?Maybe the injectors need cleaning as well.I also noticed that overnight the rail pressure was at zero and the canister was full of fuel. Seems like the fuel rail is backfeeding fuel into the VST and out the overflow. Is there a check valve in this line .I don't see one.
SOLVED !! I removed the fuel injectors and cleaned them ..One was spitting and not spraying.. After cleaning they were all spraying nicely.. Installed back in and the motor runs like a scalded dog.. Thanks and appreciate all the feedback and comments
