Next week must receive parts for the F40 that a buddy brought me from US.
Yesterday had the crankshaft polished e checked/measured at the machine shop.
Chankshaft have some wear and some main bearing marks (the guy at the machine shop said is common these 3 cyl cranks have more wear as motor doesn´t work so balanced as Ex: 4 cyl) but journals are within specifications 42.984 mm - 43.000mm (less one is 42.97*)
The guys at the machine shop are the best around and said thats not a problem.
Crank pins diameter are within spec 32.984mm - 33.000mm
If after plastigauge the bearings aren't within spec I will need a larger diameter bearings. I ordered black "B" main bearings as are the specified for that block/crankcase,
Since yamaha and most if not all outboard manufacturers don´t offer oversized bearings I tried to look for an answer googling for the diference in coulour bearings thickness (which is almost none) but had no luck, than tried to have a look on my data and got the answer on a F45A, F50A, F50B, T50 (U) and F50 (U) 1996 service manual.
This bearings are used on F25, F30, F40, (F45), F50 and maybe others but check yourself.
Have a look:
I hope this can help someone in the future.
Good luck
Have a look:
Good luck
