hydrofoils question
    Flat bottom or semi V boats tend to slide more than vees.
    Need something on the boat to grab the water. I do not think there is anything you can do on motor that will help.
    But some of the foils have adjustable things that stick down off of the bottom to help counter act prop torque like the trim tab zincs
    Good point. A Permatrim has vertical walls that extend downwards. They might help to prevent sliding but I don't see why the lower unit does not do that just as well.
    My 14' Mirrocraft (aluminum) has about the flatest bottom possible but it does have some longitudinal reinforcements running down the bottom and it never gave me nary a sliding problem. Perhaps the OP has a fiberglass boat with a baby's butt slick bottom.
      There's also other "foils" available that have a 'wing' shape to them. They would help the hole shot even more since they will create lift to help get the stern out of the hole.
