Ok still have an issue, put the boat in the water yesterday, it shifts into forward neutral and reverse fine. however when I put it in reverse it will engage and pull me backwards like you would expect, however when I give it any throttle past idle (in reverse) it wont spin up, I can hear noise like its not fully engaged or something. Not sure if my spin is still not all the way clocked right or what by everything else works fine. Anyone have any advice?
70 hp yamaha shift problem
Originally posted by 99yam40 View PostCan you explain this statement a little for meLast edited by vr4rhoads; 02-28-2015, 06:50 PM.
So what you call a spin is the shift linkage to lower unit?
Where are you located?
The slag you use is not something I recognize
Back to your problem
Take the shift cable off of the linkage on motor
with the con*****er and the motor in the neutral position
Make sure the cable will slip on to the linkage without any binding
If it will not then, adjust the cable end to where it willLast edited by 99yam40; 03-01-2015, 10:40 AM.
Yeah I didnt mean to put spin, I meant spline just didnt catch that I mispelled it sorry about that. I tried doing as you explained before and this is where its at, I checked the clocking on the spline for the lower to see if its in neutral, and it was made sure there wasnt any binding when I installed it, and I had the shift cable disconnected up top and adjusted my cable to the shift rod.
Im going to take the lower off again and clock the spline both ways and repeat the rig, might be a tooth off or something, as is when I put it into reverse with the lever (cable disconnect) the prop will not spin in reverse, however when I turn the motor on itll go into reverse and spin just wont engage fully, when I give it gas itll grid some and not spin up like if it was fully engaged. so im going to try it at the lower and see if itll go backwards from manually moving the lower unit spline, maybe ill take a video
http://youtu.be/Sf7g2kPmrdY
This is the video I just took.
This is the follow up video with the lower off. I hope this will help clarify the problem.
https://www.youtube.com/watch?v=0__lhkJWYYc
From what I see in the video, it appears the lower unit has an issue inside it...
With the shifter shaft moved fully in each direction, (LU OFF) its not fully engauging forward and reverse gears.
Please wait for others to chime in.Last edited by TownsendsFJR1300; 03-01-2015, 05:10 PM.Scott
I don't know what its supposed to look like but I would be pretty confident in that the shaft SHOULD NOT be tappered in there..
That shifter shaft should move only so far in each direction and shift that lower unit fully into either reverse or forward.
Your video show's your getting a bunch of play in the splined shifter shaft and NOT getting full engagment in either direction..
Can you please post a year AND model # so we can look at the parts fisch?Scott
Here's the parts fisch for the LU /shifter shaft;
2000 C70TLRY Yamaha Outboard LOWER CASING DRIVE 1 Diagram and Parts
Looking at that fisch, it appears that shaft goes into part #50, the "cam shift"..
Did you pull that shaft out and if so, how does the lower end of the shaft look?Last edited by TownsendsFJR1300; 03-01-2015, 09:28 PM.Scott
Â
