Hi All, I am hoping someone can help here. I have a new to me 2005 Scout Abaco and (F225 Yamaha production date dec 2005) Only 54 hours on boat and motor. Had it completely serviced and I am loving this rig.
The tach gauge reads full up and blinking. We checked the trim sender and it was reading erratic so ordered a new one here via boats.com, Well installed new on and it still reads full up and the new sender ohm chk is OK. Traced all wiring and connectors for continuity and all is good. I can bypass the wiring and connect directly to the tach and sender reads correctly. Note all wiring checks out OK all the way the the tach. It's weird but I'm thinking it has this adapter that may be incorrectly connected to the tach. The dip switches are all correct and the tach reads fine when directly connected to the pink and black trim wires from the sender directly. Any help or advice it has stumped me and the Yamaha tech that has worked on this. I have attached pics and hoping you pros might help. Thanks much.
