Im having problem around 3800Rpm*s after you run about 1/4 mile the alarm starts going ,I shut it down turn key off and right back on the alarm want be on I have changed the heat cencers change pop off valve water pump impeller .
Went had a mechanic check if there was any restriction ,He cant find what it setting off the alarm.wounder if any one has had this problem.
