Hi!
Lately my F100 is not charging like was to be...
Before this occurs just after motor start voltage was 14.6 or so at idle, now after start nothing happen and just after a while at 3500 rpm or so (my crusing rev's) voltage raise to 13.6
In fact I havenīt tested the R/R yet because after had a look under the flywheel I can see some signs of rust (little particles on the motor under the flywheel) so I want to clean it even if the problem is not here.
But now I canīt remove the flywheel
Remove the nut was easy... but not even with one person at the flywheel holder and other at the wrench something happen... even after the flywheel/crankshaft area around the thread been soaped in some kind of WD-40 oil
Carefully hammered the puller bolt after tight as I affaraid of damage the crankshaft...
Came to my mind use a heavy duty compressed air impact wrench but I'm affraid damage the crankshaft and/or the puller.
My next step may be use ICE spray to freeze the flywheel (I hope)
Any suggestions?
Any suggestions?
