2016, 150 4 stroke, just had fuel pump replaced by dealer, no problems with it, he just decided to do it at 150 hours. Now I get intermittent alarm after idling for an extended period of time. Not sure what the high temp alarm is supposed to sound like...but it's like a depth finder low water alarm, only constant, no beep....beep....beep. I turn off the ignition, and the alarm stops, sometimes re-occurs after re-starting, sometimes not. Dealer claims to have looked at the engine with a computer, saw no error codes, no abnormal temperature recorded. Dealer thinks it's the depth finder acting up.
Never had the problem before new fuel pump installed...coincidence ? Also just discovered trim tab missing...odd. In order to replace the fuel pump, is it necessary to remove the trim tab ? If it was properly torqued at 30 pounds, it seems unlikely to have just worked loose on it's own enough to fall off. Comments ?
Gemstone
Gemstone
