So yesterday I came off the water and had to clean some grass off my prop. As I was spinning the prop, I noticed a clicking noise coming from the area where the impeller would be located. It would click while spinning it clockwise and counter clockwise, almost as if it was engaging and had slack in it. I have not done anything to the engine prior to this happening. Thoughts? Is this something I should be worried about?
Engine off, clicking in neutral spinning forward and in reverse
With limited information on the reason the grass was there and why? possibly you could have picked up some mud,sand, etc. as well, that could be there causing sound? you could have damaged impeller with the debris if this happened? How does the water flow from engine running? does it indicate a good stream? if not, in any case I would still check the impeller.
Okay thank you. I have not checked the stream because I didn’t notice it until I was out of the water. It was strong before leaving for the lake. The grass I picked up was like grass beds on the bottom of the lake. I’ll be sure to do that. Thank you again.
ÂÂ
