Hi Folks,
I have a 115 V4 BETO from 1995.
We went out yesterday for the first time this year and she started first time with no problem.
The impeller was changed last year so really strong tell tale jet.
I topped off the oil tank and left the marina.
After 5 minutes or so of running the alarm went off and stayed on and she went into limp home mode.
I stopped and checked the oil tank as I thought the float may have been stuck but all looked ok but the alarm remained on.
After a 30 minute break / swim we set off again and the alarm came back on after 5 minutes or so.
When we got back home I decided to pull the thermostats and test them in a pan of water on the stove. Both thermostats opened fully at the same time as the water got hot.
(I was hoping one was not working and that it was an easy fix)
If its not the thermostats could one of the two heat sensors (or both) on either head be causing this overheat alarm if they are beginning to fail.?
Whats the best way to test that theory,? Simply removing or disconnecting them one at a time and running the engine to see if the alarm comes on.?
Will it be safe to do so now I know the thermostats are working ok.?
Thanks in advance
Stop8
Thanks in advance
Stop8
