So I was out yesterday fishing Father’s Day tournament and my motor ran fine for two hours. Shut down to fish and now won’t start? It sounded like for a split second it was going to start and then just cranks like normal no start. I checked fuel lines and filter. Took fuel filter reservoir off pumped ball got fuel easily. Checked spark on one plug good spark. I’m not very good with this motor just trying to learn please help!
Yamaha 200 ox66 won’t start
Thanks! I did manage to get it to start but still need assistance. I pumped the primer bulb a lot turned the key to on and heard the high pressure pump cycle turned the key off and pump the primer ball again and a lot turned the key to on and heard the high pressure pump cycle again tried to start and it started. So Im not sure why that didn’t work in the lake because I tried to pump the bulb and start it and it would just crank. I didn’t pump it a lot and I did not wait on the high pressure pump to cycle. Got some idea for me? I will run through the compression and all sparks not sure how to check air to fuel ratio? But thanks for your reply much appreciated!
ÂÂÂÂ
