2005 F115TLR
Low Hours-Low Usage
Starts fine, idles fine
Will NOT pull past 4,000 WOT
Can 'sneak up on it' and get it to about 4,000, maybe a bump over. If I 'throttle down' to WOT, it'll typically just seem like it is tied to an anchor and hold at about 3800.
Neutral revs, can easily blip past 5,200.
To date:
-Replaced small screen filter in VST
-Then replaced entire VST, high pressure pump, etc. with new part (YAM) (Ran exactly the same with new VST as old)
-New Plugs
-New Filters
-(also new fuel pickup in fuel tank as well as new line from tank to engine connection)
39psi at fuel rail, idle and WOT
The current 'lean' (based purely on forums) is 'injectors'. new pieces seem extremely expensive, but remans/refurbs are at least attainable, but no need to just throw even more parts on it unless others think it may be the issue.
I was hoping I was going to get a fuel pressure drop at WOT to indicate it might be the low pressure pump, but seems to stay steady at about 39
Injectors?
Other?
Thanks for any guidance.
Low Hours-Low Usage
To date:
-New Plugs
-New Filters
Injectors?
Other?
