Thanks in advance for any assistance here.
I have a 1992, 2 Stroke 225HP Yamaha outboard. It has been checked out at the mechanic and rebuilt carburetors, new fuel lines, spark plugs, new dual batteries, they went through the motor to be sure it runs great. It does, with a caveat. If I start it up when I launch the boat or at home for the first time of the day, I simply press the key in to choke it, it starts and warms up, maybe stalls a couple times maybe not. Once warm ( 1 minute or so ) I cruise off and can run Wide open throttle and the engine smoothly goes from 500RPM to say 4500RPM if I choose.
The problem shows up when I stop the engine and sit a while, say drift or simply dock it with the power on, I attempt to restart the motor and it struggles to start. When it does start, It stalls at 1000 - 1200 RPM when I try to go faster. What I have had some success (it may be coincidence) with on 3 trips so far in this case is turning ALL power off, re-priming, then starting with choke, allow warm up then it goes. What could be causing this issue?
Thanks,
Robert
Thanks,
Robert
