Originally posted by throrope
View Post
You may want to still run a stabilizer only because there's still a little of fuel in the carb float bowls that can still cause varnishing up even if run dry..
Unless you pull the bowl drain bolts, the varnish can still still accumulate.. Its cheap insurance and a whole cheaper/easier than a carb cleaning.
I've found "Gas Shok" to work extremly well as well as K100. I've personally had issues with Stabil allowing varnish to build up in as quickly as a month..
GAS SHOK - Water Absorber and Fuel Stabilizer - 32 oz [GAS SHOK 32 oz] - $39.95 : CoastUS, Marine Electronics for the Serious Boater to the Casual Fisherman
